Dell U2415 24.1" 1920x1200 6ms HDMI DisplayPort USB IPS...
£191.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Superior performance - color accuracy shines through in vivid detail over a high-performance, spacious display
  • More ways to connect - charge, connect and project handheld devices and more with extensive ports
  • Reliable and eco-efficient - count on the Dell Premium Panel Guarantee and an environmentally conscious design
  • Diagonal Size: 24.1in
  • Max Resolution: 1920 x 1200
  • Response Time: 6ms
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
  • Stock Status: In Stock
Product codes
Revel in the superior screen performance of the Dell UltraSharp 24 monitor, loaded with premium features for an exceptional viewing experience, without the premium price tag.
Position your monitor to comfortably fit the way you work with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Your Dell UltraSharp 24 Monitor - U2415 is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the Premium Panel Guarantee.
Product Description Dell UltraSharp U2415 - LED monitor - 24.1" - with 3-years Premium Panel Exchange service
Device Type LED-backlit LCD monitor - 24.1"
Energy Class Class A+
Energy Consumption per Year 26 kWh
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 2000000:1 (dynamic)
Response Time 19 ms (black-to-white); 6 ms (grey-to-grey)
Colour Support 16.8 million colours
Input Connectors 2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 53.22 cm x 20.5 cm x 40.29 cm
Weight 6.35 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play
Bundled with 3-years Premium Panel Exchange service
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell U2415 24.1" 1920x...
£191.74
