Dell U2722DE 27" 2560 x 1440 8 ms QH LED monitor
£389.35
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Connected productivity. Vibrant color.Take your work to new heights with this 27-inch QHD monitor featuring outstanding connectivity, brilliant color coverage including DCI-P3, ComfortView Plus-an always on built-in low blue light screen-and USB-C port wi
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Interfaces: HDMI, DisplayPort, USB-C
Product codes
Elevate your productivity on this innovative monitor that delivers true-to-life color and seamless connectivity.
Product Description Dell UltraSharp U2722DE - LED monitor - QHD - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class E
Power Consumption (On mode) 20.4 W
Features USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (fast), 8 ms (normal)
Colour Support 1.07 billion colours
Colour Gamut 100% Rec 709, 100% sRGB, 95% DCI-P3
Input Connectors HDMI, DisplayPort, USB-C
Built-in Ethernet Yes
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) - with stand 61.134 cm x 18.5 cm x 38.513 cm
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
Bundled Services 3 years Advanced Exchange Service
Designed For Latitude 5320, 5520; OptiPlex 3090; Precision 7560; XPS 13 9310, 15 9510
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£389.35
