Dell UltraSharp 30" 2560x1600 8ms DP HDMI Monitor
£1,078.00
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Precise color, out of the box
  • Wide color coverage
  • Exceptional detail
  • Expanded canvas
  • View tailored to you
  • Stay connected
  • Work comfortably
  • Diagonal Size: 30in
  • Max Resolution: 2560 x 1600
  • Response Time: 6ms
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort
  • Stock Status: In Stock
Product codes
Color-critical performance. 30" monitor with PremierColor that delivers every creative professional their ideal color space. You'll have precise, professional color right out of the box with flexibility to adjust it to your preferences with PremierColor. View and manage applications between two PCs simultaneously with KVM, PBP and PIP features. Or extend to a secondary monitor with a daisy chain for maximum multitasking.
Product Description Dell UltraSharp UP3017 - LED monitor - 30"
Device Type LED-backlit LCD monitor - 30"
Energy Class Class B
Energy Consumption per Year 73 kWh
Power Consumption (On mode) 54 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 2560 x 1600 at 60 Hz
Pixel Pitch 0.251 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (typical); 6 ms (fast)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Dimensions (WxDxH) - with stand 68.69 cm x 21.7 cm x 48.23 cm
Weight 9.3 kg
Environmental Standards TCO Certified Displays 8
Compliant Standards Plug and Play, RoHS, BFR
Bundled Services 3-Years Advanced Exchange Service and Premium Panel Guarantee
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell UltraSharp 30" 25...
£1,078.00
