Dell UltraSharp U2412M 24'' 1920x1200 VGA DVI-D Black...
Dell UltraSharp U2412M 24'' 1920x1200 VGA DVI-D Black Monitor
£175.24
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 8ms
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
Great performance, no matter how you look at it
Enjoy widescreen performance, any way you want it. With a 24"(61 cm) 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
  • Powerful: Experience IPS technology, featuring a wide viewing angle with high-quality colour representation for a peerless viewing experience.
  • Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
  • Customizable: Change your energy usage settings, text brightness and colour temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel
Product Description Dell UltraSharp U2412M - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 2000000:1 (dynamic)
Response Time 8 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 55.6 cm x 18 cm x 51.4 cm
Localisation United Kingdom
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Compliant Standards TCO Certified Edge
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell UltraSharp U2412M...
£175.24
