Dell Ultrasharp U2518D 25" 2560x1440 8ms HDMI DisplayPor...
Dell Ultrasharp U2518D 25" 2560x1440 8ms HDMI DisplayPort IPS LED Monitor
£292.66
Delivery:
Key features
  • With the UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking
  • The expansive 25" screen features InfinityEdge, a virtually borderless display on all four sides that lets you see more of your work
  • With seamless bezels and DisplayPort connectivity, using multiple monitors has never been easier
  • View clear images with QHD (2560x1440) resolution - nearly twice as crisp as Full HD displays
  • With excellent color consistency across a wide 178°/178° viewing angle, you can easily work and collaborate
  • Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images
Product codes
Discover ultimate efficiency with a 25" screen featuring incredibly thin bezels, ideal for a multiple monitor setup.
Dell High Dynamic Range (HDR) projects images with striking depth, captivating your attention and giving each job a gorgeous finish.
Multitask in comfort on this device with a fully adjustable stand, Dell Display Manager and ComfortView.
Product Description Dell UltraSharp U2518D - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class B
Energy Consumption per Year 44 kWh
Power Consumption (On mode) 30 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.216 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (normal); 5 ms (fast)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Dimensions (WxDxH) - with stand 56.76 cm x 20.01 cm x 39.72 cm
Weight 5.89 kg
Compliant Standards Plug and Play, TUV, RoHS
Designed For Latitude 7400 2-in-1; XPS 13 9380, 15 9570, 15 9575 2-in-1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell Ultrasharp U2518D...
£292.66
