Experience true color reproduction on this 25" QHD monitor a wide color coverage.
Product Description | Dell UltraSharp U2520D - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class F | Power Consumption (On mode) | 22 W | Features | USB PD 90 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.216 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 16.8 million colours | Colour Gamut | 95% DCI-P3, 99% Rec 709, 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 56.77 cm x 18.5 cm x 38.29 cm | Weight | 6.4 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | RoHS, BFR-free, PVC-free, Mercury-free | Bundled Services | 3 years Advanced Exchange Service | Designed For | Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class E |
Diagonal Size | 25" |
USB Power Delivery | 90 Watt |
Panel Type | IPS |
Pixel Per Inch | 117.5 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | LED edgelight system, Delta E<2 calibration, 99% sRGB colour gamut |
Dimensions (WxDxH) | 56.77 cm x 18.5 cm x 38.29 cm - with stand |
Weight | 6.4 kg |
Connectivity | |
Interfaces | DisplayPort 1.4 , DisplayPort output (MST) , HDMI , USB-C (power up to 90W) , 2 x USB 3.0 downstream , USB 3.0 downstream with Battery Charging 1.2 , USB-C downstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection |
Cables Included | 1 x USB-C cable , 1 x HDMI cable , 1 x USB-C to USB-A cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 22 kWh/1000h |
Power Consumption HDR (On mode) | 16.1 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.77 cm - depth: 18.5 cm - height: 38.29 cm - weight: 6.4 kg , Without stand - width: 56.77 cm - depth: 4.99 cm - height: 33.21 cm - weight: 4.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 8.8 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
