General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Diagonal Size |
27" |
Viewable Size |
27" |
Built-in Devices |
USB 3.0 hub |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
QHD 2560 x 1440 at 60 Hz |
Pixel Pitch |
0.2331 mm |
Brightness |
350 cd/m² |
Contrast Ratio |
1000:1 |
Colour Support |
16.7 million colours |
Response Time |
8 ms (typical); 6 ms (fast) |
Vertical Refresh Rate |
50 - 75 Hz |
Horizontal Refresh Rate |
30 - 88 kHz |
Video Bandwidth |
241.5 MHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating |
Backlight Technology |
LED backlight |
Colour Temperature |
9300K, 5000K, 6500K, 7500K, 10000K, 5700K |
Features |
LED edgelight system, Mobile High-Definition Link (MHL), stand lock, 99% sRGB colour gamut |
Colour |
Black |
Dimensions (WxDxH) |
61.13 cm x 20.03 cm x 41.02 cm - with stand |
Weight |
7 kg |
Connectivity |
Interfaces |
MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+21 |
Swivel Angle |
90 |
Rotation Angle |
180 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support |
Included Accessories |
Stand |
Cables Included |
1 x USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m |
Compliant Standards |
Plug and Play, VESA EDID, FCC, DDC/CI, RoHS |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
74 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption Sleep |
0.3 Watt |
Software / System Requirements |
Included Software |
Drivers & Utilities, Dell Display Manager |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 61.13 cm - depth: 20.03 cm - height: 41.02 cm - weight: 7 kg , Without stand - width: 61.13 cm - depth: 4.83 cm - height: 35.56 cm - weight: 4.5 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years |
Bundled Services |
3 years Advanced Exchange Basic Warranty |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
