Dell UltraSharp U2717D 27" 2560x1440 8ms HDMI LED LCD Mo...
£331.95
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Seamless and precise with thin borders on all sides of the screen, creating an almost seamless multi-monitor view
  • Designed with purpose due to multiple customization possibilities allowing you to adjust your monitor to best fit the way you work
  • Unmatched reliability
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 6ms
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
  • Stock Status: In Stock
Product codes
The Dell UltraSharp 27 InfinityEdge monitor U2717D takes your view to the edge with less borders.
Product Description Dell UltraSharp U2717D - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1
Response Time 8 ms (typical); 6 ms (fast)
Colour Support 16.7 million colours
Input Connectors HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 61.13 cm x 20.03 cm x 41.02 cm
Weight 7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VESA EDID, FCC, DDC/CI, RoHS
Bundled Services 3 years Advanced Exchange Basic Warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell UltraSharp U2717D...
£331.95
