Elevated productivity. Vibrant color. Take your work to new heights with this 27-inch QHD monitor featuring wide color coverage, ComfortView Plus and fast connectivity.
Product Description | Dell UltraSharp U2722D - LED monitor - QHD - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Power Consumption (On mode) | 20 W | Features | USB 3.2 Gen 2/USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 1.07 billion colours | Colour Gamut | 100% Rec 709, 100% sRGB, 95% DCI-P3 | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 61.134 cm x 18.5 cm x 38.513 cm | Environmental Standards | TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free | Bundled Services | 3 years Advanced Exchange Service | Designed For | Latitude 5320, 5520; OptiPlex 3090; Precision 7560 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.2 Gen 2/USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 108.78 |
Vertical Refresh Rate | 49 - 76 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, OSD lock, integrated cable management, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, Delta E<2 calibration |
Dimensions (WxDxH) | 61.134 cm x 18.5 cm x 38.513 cm - with stand |
Connectivity | |
Interfaces | HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption (Max) | 74 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.134 cm - depth: 18.5 cm - height: 38.513 cm , Without stand - width: 61.134 cm - depth: 4.95 cm - height: 35.201 cm - weight: 4.38 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 9.62 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
