Brilliant color and clarity for your best work. Experience outstanding screen performance on this 31.5" 4K USB-C monitor featuring InfinityEdge and multitasking capabilities.
Product Description | Dell UltraSharp U3219Q - LED monitor - 4K - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Consumption per Year | 63 kWh | Power Consumption (On mode) | 39.8 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.182 mm | Brightness | 400 cd/m² | Contrast Ratio | 1300:1 | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 1.07 billion colours | Colour Gamut | 95% DCI-P3, 99% Rec 709, 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71.25 cm x 22 cm x 46.873 cm | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | DisplayPort 1.4, HDCP 2.2 | Bundled Services | 3 years Advanced Exchange Service | Designed For | OptiPlex 3090; Precision 7560; XPS 13 9310, 13 9380, 15 9510, 15 9570 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 140 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | LED edgelight system, Infinity Edge display, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 71.25 cm x 22 cm x 46.873 cm - with stand |
Connectivity | |
Interfaces | USB-C upstream/DisplayPort Alt Mode with Power Delivery , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 downstream with Battery Charging 1.2 , 2 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 60 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable , 1 x SuperSpeed USB cable - USB Type A to B |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 46 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.25 cm - depth: 22 cm - height: 46.873 cm , Without stand - width: 71.25 cm - depth: 4.45 cm - height: 41.45 cm |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
Manufacturer Warranty | |
Compatibility Information | |
Designed For | Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 13 9380, 15 9510, 15 9570 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
