Be your most productive on a 31.5" 4K monitor with brilliant color and contrast that features groundbreaking IPS Black technology and a connectivity hub.
Product Description | Dell UltraSharp U3223QE - LED monitor - 4K - 31.5" - with 3-year Basic Advanced Exchange (CA, US - 3-year Advanced Exchange Service) | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class F | Power Consumption (On mode) | 29.4 W | Features | USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.18159 mm | Brightness | 400 cd/m² | Contrast Ratio | 2000:1 / 2000:1 (dynamic) | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 1.07 billion colours | Colour Gamut | 100% Rec 709, 100% sRGB, 98% DCI-P3 | Input Connectors | HDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand (lowest position) | 71.261 cm x 23.317 cm x 46.934 cm | Weight | 10.36 kg | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold | Compliant Standards | RoHS, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free | Bundled Services | 3 years Advanced Exchange Basic Warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class E |
Diagonal Size | 31.5" |
Built-in Devices | USB 3.2 Gen 2/USB-C hub |
USB Power Delivery | 90 Watt |
Panel Type | IPS |
Pixel Per Inch | 137.68 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless |
Colour | Black |
Dimensions (WxDxH) | 71.261 cm x 23.317 cm x 46.934 cm - with stand (lowest position) |
Weight | 10.36 kg |
Connectivity | |
Interfaces | HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream (data only) , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 60 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B , 1 x USB-C to USB-C cable - 1 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 29.4 kWh/1000h |
Power Consumption HDR (On mode) | 26.1 kWh/1000h |
Power Consumption (Max) | 220 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (lowest position) - width: 71.261 cm - depth: 23.317 cm - height: 46.934 cm - weight: 10.36 kg , Without stand - width: 71.261 cm - depth: 5.578 cm - height: 41.004 cm |
Dimensions & Weight (Shipping) | |
Shipping Weight | 14.49 kg |
Environmental Standards | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
