Dell UltraSharp 34 Curved USB-C Hub Monitor | U3421WE -86.72cm (34.14).
Product Description | Dell UltraSharp U3421WE - LED monitor - curved - 34.1" | Device Type | LED-backlit LCD monitor - 34.1" | Energy Class | Class F | Power Consumption (On mode) | 31.6 W | Curved Screen | Yes | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | WQHD 3440 x 1440 at 60 Hz | Pixel Pitch | 0.2325 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 81.36 cm x 23.74 cm x 39.28 cm | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | DisplayPort 1.2, DisplayPort 1.4 | Bundled Services | 3 years Advanced Exchange Basic Warranty | Designed For | Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34.1" |
Curved Screen | Yes (1900R) |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 48 - 85 Hz |
Horizontal Refresh Rate | 30 - 89 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | LED edgelight system |
Dimensions (WxDxH) | 81.36 cm x 23.74 cm x 39.28 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort 1.4 , USB-C/DisplayPort 1.2 Alt Mode , USB 3.2 Gen 1 upstream (Type B) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 2 x USB 3.2 Gen 1 downstream , Audio line-out , Network (RJ-45) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 60 |
Height Adjustment | 150 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable , 1 x HDMI cable - 1.8 m , 1 x USB-C cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 31.6 kWh/1000h |
Power Consumption (Typical) | 36 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.36 cm - depth: 23.74 cm - height: 39.28 cm , Without stand - width: 81.36 cm - depth: 5.75 cm - height: 35.91 cm - weight: 7.52 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 16.5 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
