The 49-inch curved dual QHD monitor with the revolutionary ultra-wide 32:9 aspect ratio for seamless multi-screen productivity. Delivering an immersive experience, this expansive monitor is the ideal replacement for two 27-inch QHD monitors. The large onscreen space with 5120 x 1440 resolution and IPS technology allows users to view more content and see fine details with consistent color across a wide viewing angle.
Product Description | Dell UltraSharp U4919DW - LED monitor - curved - 49" | Device Type | LED-backlit LCD monitor - 49" | Energy Class | Class G | Energy Consumption per Year | 74 kWh | Power Consumption (On mode) | 47 W | Curved Screen | Yes | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 32:9 | Native Resolution | Dual Quad HD 5120 x 1440 at 60 Hz | Pixel Pitch | 0.234 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 1.07 billion colours | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 121.51 cm x 25.26 cm x 45.86 cm | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | DisplayPort 1.4, HDCP 2.2 | Bundled Services | 3 years Advanced Exchange Service | Designed For | OptiPlex 3090; Precision 7560; XPS 15 9570 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 49" |
Curved Screen | Yes (3800R) |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 109 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Picture by picture, 10-bit gamma, LED edgelight system, Delta E<2 calibration |
Dimensions (WxDxH) | 121.51 cm x 25.26 cm x 45.86 cm - with stand |
Connectivity | |
Interfaces | 2 x HDMI (HDCP) , DisplayPort (HDCP) , 2 x USB 3.0 upstream , 5 x USB 3.0 downstream , USB-C/DisplayPort 1.4 Alt Mode |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 340 |
Height Adjustment | 90 mm |
VESA Mounting Interface | Yes |
Miscellaneous | |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 47 kWh/1000h |
Power Consumption (Typical) | 60 Watt |
Power Consumption (Max) | 230 Watt |
Power Consumption Stand by | 0.4 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
On / Off Switch | No |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 121.51 cm , Without stand - width: 121.51 cm - height: 37.1 cm - weight: 11.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 26.43 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Humidity Range Operating | 20 - 80% (non-condensing) |
Compatibility Information | |
Designed For | Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 15 9570 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
