Dell UltraSharp 27 PremierColor Monitor - UP2716DA - 69cm(27) Black UK.
Product Description | Dell UltraSharp UP2716DA - LED monitor - 27" - with 3-year Basic Advanced Exchange | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 89.3 kWh | Power Consumption (On mode) | 30.5 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 2000000:1 (dynamic) | Response Time | 14 ms (typical), 6 ms (fast) | Colour Support | 1.07 billion colours | Colour Gamut | 100% Adobe RGB, 100% Rec 709, 100% sRGB, 98% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.14 cm x 20.03 cm x 41.03 cm | Weight | 7.42 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VESA EDID, FCC, DDC/CI, RoHS, DDC, HDCP 1.4 | Bundled Services | 3 years Advanced Exchange Basic Warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 88 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 5000K, 10000K |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features | Picture in picture, picture by picture, PremierColor technology, CustomColor Mode, Multi-Stream transport (MST), The Paper Mode, BFR/PVC-free, Energy Gauge, Mercury free, Colour Calibration, arsenic-free glass, Factory Calibration Report, Colour Temperature Selection, Movie Mode, Multimedia Mode, ultra-thin bezel design, 3-sided bezeless |
Colour | Black |
Dimensions (WxDxH) | 61.14 cm x 20.03 cm x 41.03 cm - with stand |
Weight | 7.42 kg |
Connectivity | |
Interfaces | 2 x HDMI (HDCP 1.4) , DisplayPort (HDCP 1.4) , Mini DisplayPort (HDCP 1.4) , 2 x USB 3.0 upstream (Type B) , USB 3.0 downstream with Battery Charging 1.2 (Type A) , USB 3.0 downstream (Type A) , DisplayPort output (MST) , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot |
Cables Included | 1 x USB 3.0 upstream cable - 1.8 m , 1 x Mini DisplayPort cable - miniDisplayPort to DisplayPort - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 30.5 kWh/1000h |
Power Consumption (Typical) | 30.5 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.14 cm - depth: 20.03 cm - height: 41.03 cm - weight: 7.42 kg , Without stand - width: 61.14 cm - depth: 5.14 cm - height: 36.25 cm - weight: 4.56 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 9.52 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
