General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class C |
Energy Consumption per Year |
85 kWh |
Diagonal Size |
32" |
Viewable Size |
31.5" |
Built-in Devices |
USB 3.0 hub, SD/MS/MMC card reader |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
4K UHD (2160p) 3840 x 2160 at 60 Hz |
Pixel Pitch |
0.182 mm |
Brightness |
300 cd/m² |
Contrast Ratio |
1000:1 / 2000000:1 (dynamic) |
Colour Support |
1.07 billion colours |
Response Time |
6 ms |
Vertical Refresh Rate |
24 - 75 Hz |
Horizontal Refresh Rate |
30 - 140 kHz |
Video Bandwidth |
533.25 MHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating |
Backlight Technology |
LED backlight |
Colour Temperature |
5000K, 10000K |
Controls & Adjustments |
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, uniformity, hue, aspect control, colour space, gain, offset |
OSD Languages |
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features |
Picture by picture, PremierColor technology, LED edgelight system, 100% sRGB colour gamut, Picture-in-Picture Plus, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, 99.5% Adobe RGB colour gamut, arsenic-free glass, Factory Calibration Report, 100% Rec 709 colour gamut, 87% DCI-P3 |
Colour |
Black |
Dimensions (WxDxH) |
74.99 cm x 21.4 cm x 48.26 cm - with stand |
Weight |
11.2 kg |
Bundled with |
3-Years Advance Exchange Service |
Connectivity |
Interfaces |
DisplayPort , Mini DisplayPort , MHL / HDMI , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-out |
Mechanical |
Display Position Adjustments |
Height, swivel, tilt |
Tilt Angle |
- 5.5/+22 |
Swivel Angle |
60 |
Height Adjustment |
90 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots |
Included Accessories |
Stand, cable management cover |
Cables Included |
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mobile High-Definition Link (MHL)-HDMI cable - 1.8 m |
Compliant Standards |
Plug and Play, VESA EDID, DDC/CI, RoHS |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
130 Watt |
Power Consumption Stand by |
0.3 Watt |
Power Consumption Sleep |
0.3 Watt |
Software / System Requirements |
Included Software |
Display drivers, Dell Display Manager |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 74.99 cm - depth: 21.4 cm - height: 48.26 cm - weight: 11.2 kg , Without stand - width: 74.99 cm - depth: 5.15 cm - height: 44.46 cm - weight: 8.6 kg |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 80% (non-condensing) |
