Dell Vostro 3578 i3-8130U 4GB RAM 1TB 15.6" Windows 10 Pro
Sorry but this product has been discontinued.
View used stock
Key features
  • Easy output
  • Lightning-fast connectivity
  • Burn, read, write and load
  • Display Size: 15.6in
  • Processor Model: I3-8130U
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 4GB, 4GB
  • Hard Drive Capacity: 1TB
Product codes
The display offers rich viewing when you're working on spreadsheets, budgets or email. Collaborate remotely or take your meetings online with the built-in webcam.
Product Description Dell Vostro 3578 - 15.6" - Core i3 8130U - 4 GB RAM - 1 TB HDD
Product Type Notebook
Operating System Win 10 Pro 64-bit
Processor Intel Core i3 (8th Gen) 8130U / 2.2 GHz (3.4 GHz) / 4 MB Cache
Memory 4 GB DDR4 (1 x 4 GB)
Storage 1 TB HDD / 5400 rpm
Optical Drive DVD-Writer
Display 15.6" 1366 x 768 / HD
Graphics Intel UHD Graphics 620
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 4-cell
Security Trusted Platform Module (TPM 2.0) Security Chip
Colour Black
Dimensions (WxDxH) 38 cm x 26 cm x 2.365 cm
Weight 2.18 kg
Pricing Type Build To Stock (BTS)
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year - pick-up and return
Bundled Services 1 Year Dell Collect and Return Service
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: F16P 040899
£348.38
product
Ref: F16P 040899
Accessories
Packaging
Functional
Software
Manuals
£348.38
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell Vostro 3578 i3-81...
