Dell XPS 15 7590 Core i5-9300H 8GB 256GB SSD 15.6" Win 1...
Dell XPS 15 7590 Core i5-9300H 8GB 256GB SSD 15.6" Win 10 Pro
£1,085.73
Delivery:
Key features
  • Revolutionary webcam construction
  • InfinityEdge display
  • Deep contrast
  • Dazzling detail
  • Industry-leading color
  • Beautiful from any angle
  • Display Size: 15.6in
  • Processor Model: I5-9300H
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 256GB
Product codes
The XPS 15 webcam isn't just smaller - it's also better. A 4-element lens uses more elements than a typical webcam to deliver sharp video in all areas of the frame, while temporal noise reduction uses advanced noise reduction, significantly improving video quality, especially in dim lighting conditions. Finally, the lens is assembled with precise machinery to ensure all points of the image are in focus.
Product Description Dell XPS 15 7590 - 15.6" - Core i5 9300H - 8 GB RAM - 256 GB SSD
Product Type Notebook
Operating System Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Processor Intel Core i5 (9th Gen) 9300H / 2.4 GHz (4.1 GHz) / 8 MB Cache
Memory 8 GB DDR4 (2 x 4 GB)
Storage 256 GB SSD NVMe
Optical Drive No optical drive
Display 15.6" WLED 1920 x 1080 / Full HD
Graphics NVIDIA GeForce GTX 1650
Video Memory 4 GB GDDR5 SDRAM
Keyboard Backlight Yes
Integrated Webcam Yes
Networking Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
Battery 3-cell
Security Fingerprint reader
Colour Silver
Dimensions (WxDxH) 35.7 cm x 23.5 cm x 1.7 cm
Weight 1.8 kg
Pricing Type Build To Spec (BTS)
Environmental Standards ENERGY STAR Qualified
Bundled Services 1 Year Dell ProSupport
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: FP1X 042736
£987.92
product
Ref: FP1X 042736
Accessories
Packaging
Functional
Software
Manuals
£987.92
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Dell XPS 15 7590 Core...
£1,085.73
