Devolo dLAN® 500 WiFi Starter Kit
£80.20
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Your home network from the power outlet
  • WiFi Move technology is the intelligent expansion of your existing Wi-Fi network
  • Uninterrupted, full-strength Wi-Fi
  • Compact design for convenient placement throughout the home, at any power outlet
  • Good Wi-Fi connection for smartphones, laptops and tablets
  • Continuous Internet performance for all Internet-compatible devices
  • Type: Bridge
  • Speed: 500Mbps
  • Connectivity: Wired, Wireless
  • Pass-through Socket: No
  • Stock Status: Clearance
Product codes
dLAN 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection.
As a Powerline adapter, the dLAN 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room.
The integrated wireless LAN also provides complete Internet coverage to every nook and cranny.
Smartphones, tablets and laptops have full-strength coverage right from the start without any problems. An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection. Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place. The dLAN 500 WiFi from devolo brings the future to your home.
Product Description devolo dLAN 500 WiFi - Starter Kit - bridge - 802.11b/g/n - wall-pluggable
Device Type Bridge
Packaged Quantity 2 (specifications are for single item)
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band 2.4 GHz
Data Transfer Rate 500 Mbps
Network / Transport Protocol CSMA/CA
Features Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
Power AC 230V (50 Hz)
Dimensions (WxDxH) 6.8 cm x 4.1 cm x 6.8 cm
System Requirements Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Devolo dLAN® 500 WiFi...
£80.20
