Devolo Magic 1 LAN Starter Kit (1x LAN, Pass-Thru, 2x plugs)
£99.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Friday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • - Latest Powerline Technology
  • - Up to 1200 Mbps
  • - 1Gb LAN port
  • - Up to 400m range
  • Type: Bridge
  • Speed: 1200Mbps
  • Connectivity: Wired
  • Pass-through Socket: Yes
Product codes
Documents
devolo Magic 1 LAN – reliable home network via Powerline
Uncomplicated and incredibly powerful – the devolo Magic 1 LAN Powerline adapter gives you stable internet for your home via the power socket. With its long range of 400 meters, the dLAN adapter opens up rooms that previously had no network connection: Online gaming on your terrace, potter about with the help of YouTube-Tutorials in your basement workshop, or an efficient home office in the attic – there are no limits to your ideas and plans. Just plug devolo Magic 1 LAN into the power socket and connect with the other Magic adapters. Intelligent Plug & Play completes the configuration for you in seconds. The Powerline adapter immediately connects to the internet at the high speed of 1200 Mbps through your home network.
Surf at high speed, stream the latest blockbusters and series, and listen to music via streaming portals in different rooms at the same time – devolo Magic 1 LAN does the trick. devolo Magic 1 LAN gives passionate online gaming fans their money’s work, too. Immerse yourself in multi-player mode or tackle the latest gaming adventures alone with no lags or crashes. Those who prefer to be productive simply send the magical internet to their home offices.
The Powerline adapter ensures that you can work securely, reliably, and at a high transfer rate.
Let yourself be inspired by the new multimedia applications – devolo Magic adapters are already ade for the future. They are based on the sustainable G.hn standard and are compatible with all products certified by the HomeGrid Forum.
The Gigabit LAN port allows you to connect a wide variety of stationary terminal devices, such as Smart TV, game console, or PC, to the Magic network. However, whenever, and as often as you want. You don’t even have to give up a wall socket – each devolo Magic adapter is equipped with an integrated power socket with child safety for convenience and security. And to help you keep an eye on your home network, there is the Home Network App. It gives you an overview of all connected devices and allows you to control them intuitively and with ease via your smartphone. The devolo Magic 1 LAN adapter is available individually or in a practical Starter Kit of two Powerline adapters. devolo Magic 1 LAN can also be used with all other devolo Magic adapters to form a home network that makes everything possible. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a Magic-only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
  • With a transfer rate of up to 1,200 Mbps including latest G.hn technology.
  • Outstandingly cost-effective Magic adapter with future-proof G.hn technology.
  • High-speed home network over the electrical wiring from the German pioneer and market leader.
  • 1 x Gigabit LAN easily connects static devices such as smart TVs, game consoles or computers.
Product Description devolo Magic 1 LAN - Starter Kit - bridge - wall-pluggable
Device Type Bridge
Packaged Quantity 2 (specifications are for single item)
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
Features Auto-uplink (auto MDI/MDI-X), reset button
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Power AC 230V (50 Hz)
Dimensions (WxDxH) 6.6 cm x 4.2 cm x 13 cm
System Requirements Microsoft Windows 7 or later, Apple MacOS X 10.9 or later, Android 5.0 or later, Apple iOS 9 or later, Ubuntu 14.04 or later
Resources
The following resources are available for the Devolo Magic 1 LAN Starter Kit (1x LAN, Pass-Thru, 2x plugs)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£99.99
