devolo Magic 1 WiFi – the WiFi extender of the future is here.
Mobile surfing without making compromises – devolo Magic 1 WiFi brings stable internet to your home, wherever you need it, at excellent speeds. High-speed surfing on the balcony? Watching YouTube tutorials in the basement workshop? Streaming films in the garden? devolo Magic allows you to enjoy endless multi media fun in high quality. devolo Magic 1 WiFi brings you reliable Internet with ease. Just plug the magical Powerline adapter into a wall socket and have Plug & Play connect you to other devolo Magic adapters. The latest generation of devolo’s WiFi adapters brings internet to your terminal devices at speeds of up to 1200 Mbps, whether it is a PC, Smart TV, game console, tablet, or mobile. Amazingly simple – you don’t have to do anything. And to keep you from losing track of it all, the intuitive Home Network App ensures that you can keep an eye on all connected adapters from your smartphone.
The devolo Magic adapter has two Fast Ethernet LAN connections, allowing you to integrate your stationary devices into your mesh home network with ease. Its high range of up to 400 metres ensures a strong connection, from the basement to the attic, from your garage, balcony, or terrace to the garden. devolo Magic 1 WiFi uses the ac standard, operates the Multiroom WiFi frequencies of 2.4 and 5 GHz at the same time, and is what makes the excellent speeds of up to 1200 Mbps possible. For you, that means surfing at high speed and seamless streaming in HD at the same time, anywhere in the house. Airtime Fairness gives faster devices ‘right of way’ in the home network. This ensures uninterrupted streaming enjoyment without lags or crashes while your children play online games on the tablet. Simply ideal for your digital everyday life! And to make sure you don’t lose your signal on your smartphone, devolo Magic 1 WiFi works with real Mesh WiFi. The WiFi adapter ensures a gapless network and provides you with freedom – it’s up to you to use it! Transform your house or flat into a smart home or make a universal cloud work station of your PC. Build on the stable and powerful connection of the Magic home network. The latest encryption technology also ensures optimal security for your data. With ease – activated at the touch of a button – the WiFi adapter activates 128-bit AES for the Powerline connection and WPA2 for WiFi ac, whenever you need it. As one of the first adapters on the market Magic is also ready for WPA3. That is internet technology at its highest level – today, tomorrow, and in the future. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a Magic-only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
Product Description | devolo Magic 1 WiFi - Starter Kit - bridge - 802.11a/b/g/n/ac - wall-pluggable | Device Type | Bridge | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 1200 Mbps | Features | Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), reset button, 2T2R MIMO technology | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11ab | Power | AC 230V (50 Hz) | Dimensions (WxDxH) | 7.6 cm x 4 cm x 15.2 cm | System Requirements | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Max Range Open Space | 400 m |
Encryption Algorithm | WPA, WPA2, 128-bit AES |
Status Indicators | Link/activity, powerline, Wi-Fi |
Line Properties | |
Line Coding Format | 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM |
Expansion / Connectivity | |
Interfaces | 1 x power , LAN: 2 x 10Base-T/100Base-TX - RJ-45 |
Aerial | |
Aerial | Internal |
Antenna Qty | 4 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 230V (50 Hz) |
Power Consumption Operational | 5.1 Watt |
Miscellaneous | |
Included Accessories | Devolo MAGIC 1 LAN adapter |
Cables Included | 1 x network cable - 2 m |
Software / System Requirements | |
OS Required | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 |
Dimensions & Weight | |
Width | 7.6 cm |
Depth | 4 cm |
Height | 15.2 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 18.8 cm |
Shipping Depth | 23.1 cm |
Shipping Height | 9.2 cm |
Shipping Weight | 890 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
The following resources are available for the Devolo Magic 1 WiFi Starter Kit (2x LAN, Pass-Thru, 2x plugs)
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
