Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
Product Description | devolo Magic 2 LAN triple - bridge - wall-pluggable | Device Type | Bridge | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid | Features | Auto-uplink (auto MDI/MDI-X), reset button | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az | Dimensions (WxDxH) | 7.2 cm x 4.1 cm x 14.3 cm | System Requirements | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wired |
Encryption Algorithm | 128-bit AES |
Status Indicators | Powerline |
Line Properties | |
Line Coding Format | 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM |
Expansion / Connectivity | |
Interfaces | 1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 5 Watt |
Miscellaneous | |
Cables Included | Network cable - 2 m |
Software / System Requirements | |
OS Required | Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10 |
Dimensions & Weight | |
Width | 7.2 cm |
Depth | 4.1 cm |
Height | 14.3 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 19 cm |
Shipping Depth | 11.8 cm |
Shipping Height | 9.2 cm |
Shipping Weight | 470 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
The following resources are available for the Devolo Magic 2 LAN TRIPLE Add-On Adapter (3x LAN, Pass-Thru)
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
