Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x...
Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
£140.37
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Three times faster fast: three Gigabit LAN ports with a top speed of 2400 Mbps
  • Fast internet anywhere: magic 2 LAN triple crosses long distances (up to 500 meters)
  • High performance with unbeatable network stability: the Magic 2 LAN triple uses all three wires in the power grid
  • Type: Bridge
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
Documents
Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
Product Description devolo Magic 2 LAN triple - Starter Kit - bridge - wall-pluggable
Device Type Bridge
Enclosure Type Wall-pluggable
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
Features Auto-uplink (auto MDI/MDI-X), reset button
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Dimensions (WxDxH) 7.2 cm x 4.1 cm x 14.3 cm
System Requirements Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.9, Android 5.1, Ubuntu 16.04, Apple iOS 10
Resources
The following resources are available for the Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Devolo Magic 2 LAN TRI...
£140.37
