We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
devolo Mesh WiFi: All devolo units form a coherent network that not only amplifies your router WiFi, but also replaces it optimally – for seamless reception.
Mesh Wi-Fi in its best form
Surf without gaps! Unlike conventional starter kits for home networking, the devolo Mesh WiFi set consists exclusively of WiFi units that replace your existing router WiFi with a pure mesh network. Up to 100 terminal devices can be supplied with WiFi at maximum gigabit speeds in a cohesive network. Eradicate wireless gaps and experience the best network coverage!
The fastest tri-band of its class
WiFi ac meets Powerline: Perfect Wi-Fi is transmitted to all end devices over two frequencies (2.4 and 5 GHz) with secure encryption. The devolo units distribute the Internet signal via power line throughout the home, ensuring a lightning-fast, stable network!
Adapts to your home!
The devolo Mesh WiFi network can be flexibly expanded at any time – you can easily connect additional devolo units to the existing network at the touch of a button. In the devolo mesh network, all settings for data security and performance optimisation are automatically synchronised.
A tip for even better mesh performance
For unimpaired performance, please switch off the router Wi-Fi. The devolo units then form a pure devolo mesh network. By using this trick, you enable the full range of functions of the perfectly co-ordinated devolo units and provide a performance boost – particularly in the case of older routers. Now your end devices will no longer be throttled by obsolete router Wi-Fi.
A real team player
devolo Mesh WiFi adapters are compatible with all Wi-Fi routers, Wi-Fi-capable devices and, of course, devolo Magic adapters. dLAN® Powerline adapters and other HomePlug AV products, including the devolo Outdoor WiFi Powerline adapters, are not supported.
Product Description | devolo Mesh Wifi 2 - Starter Kit - powerline adapter kit - 802.11a/b/g/n/ac - wall-pluggable | Device Type | Powerline adapter kit | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 2400 Mbps | Features | Auto-uplink (auto MDI/MDI-X), IPv6 support, parental control, Mesh networking, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), integrated power socket, reset button, IPv4 support, SISO technology, Airtime Fairness, 2x2 MIMO technology | Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v | Power | AC 230V (50 Hz) | Dimensions (WxDxH) | 7.6 cm x 4 cm x 15.2 cm | Localisation | United Kingdom | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPS, WPA3-Personal |
Status Indicators | Power, link/activity, Wi-Fi |
Expansion / Connectivity | |
Interfaces | 1 x HomePNA - power Type G , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Aerial | |
Aerial | Internal |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 230V (50 Hz) |
Power Consumption Operational | 8.9 Watt |
Miscellaneous | |
Cables Included | 1 x network cable - 2 m |
Dimensions & Weight | |
Width | 7.6 cm |
Depth | 4 cm |
Height | 15.2 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 23.1 cm |
Shipping Depth | 9.2 cm |
Shipping Height | 18.8 cm |
Shipping Weight | 1.035 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
The following resources are available for the Devolo Mesh WiFi 2 Starter Kit
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
