The Mavic 2 Zoom sports a 1/2.3 inch 12-megapixel sensor and two-times optical zoom lens (24mm - 48mm, 35 equivalent), allowing users to capture everything from wide angle to mid-range shots for more creative options.
Product Description | DJI Mavic 2 Zoom - quadcopter | Product Type | Quadcopter | Category | Vehicles - drones | Compatibility | iPhone, iPad, Android phone | Camera | Included - 12 Megapixel | Max Speed | 72 kilometers per hour | Navigation | GPS/GLONASS receiver | Interface | Wi-Fi | Width | 24.2 cm | Depth | 32.2 cm | Height | 8.4 cm |
General | |
Size | 354 mm |
Remote Control | Yes - 2.4 GHz - max operating distance: 8 km |
Power Source | Battery |
Card Reader | microSDXC UHS-I Memory Card up to 128 GB |
Features | Battery charger, remote controller, camera with gimbal, intelligent flight battery, obstacle avoidance system |
RC Vehicle | |
Take-Off Weight | 907 g |
Vertical Hovering Accuracy | +/- 0.1 metres |
Horizontal Hovering Accuracy | +/- 0.3 metres |
Max Angular Velocity | 200° per second |
Max Tilt Angle | 35° |
Max Vertical Velocity | 5 metres per second |
Max Horizontal Velocity | 20 metres per second |
Interface | Wi-Fi |
Gimbal | |
Control Angle Range | -90 to 30° (tilt), -75 to 75° (pan) |
Max Speed | 120° per second (tilt) |
Digital Camera | |
Sensor Resolution | 12 Megapixel |
Image Sensor Type | CMOS |
Capture Formats | MOV (MPEG-4 AVC/H.264), MP4 (MPEG-4 AVC/H.264) |
Video Recorder Resolutions | 1920 x 1080 (1080p), 3840 x 2160 (2160p), 2688 x 1512 |
Frame Rate | 30 frames per second |
Still Image Formats | JPEG, DNG |
Still Image Resolutions | 4000 x 3000 |
Max View Angle | 83 degree(s) |
Battery | |
Rechargeable Battery | Rechargeable |
Supported Battery Configurations | 4S |
Technology | Lithium polymer |
Voltage | 15.4 V |
Capacity | 3850 mAh |
Run Time | Up to 31 min |
Miscellaneous | |
Dimensions | 32.2 cm x 24.2 cm x 8.4 cm |
Choking Hazard Warnings | |
Dimensions & Weight Details | Folded - 9.1 cm x 21.4 cm x 8.4 cm , Battery - 297 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 40 °C |
