DJI Mavic Air Fly More Combo Drone - Onyx Black
£949.00
Colours:
40 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
A marvel of engineering and design, the Mavic Air was built to go wherever adventure takes you. This ultraportable and foldable drone features high-end flight performance and functionality for limitless exploration.
3-Axis Gimbal Camera
The Mavic Air is the most portable DJI drone to house a 3-axis mechanical gimbal, with its angular vibration range reduced to 0.005°. Set in a triangular formation, gimbal dampeners help create even steadier shots.
32 MP Sphere Panoramas
In addition to Horizontal, Vertical, and 180° panoramas, the Mavic Air stitches 25 photos together in just eight seconds to create crystal-clear 32 MP Sphere panoramas.1 View them from an immersive perspective with DJI Goggles.
4K 100 Mbps Video
The Mavic Air shoots video at an incredible 4K 30 fps, recording at 100 Mbps to capture every second with UHD quality.
Slow-Motion Video
With support for recording 1080p 120 fps slow-motion video, the Mavic Air captures all your epic high-speed adventures.
HDR Photos
New HDR algorithms help you obtain the right exposure settings intelligently, according to lighting conditions. Overexposed or dark areas are processed for more natural transitions between highlights and shadows, while DSP acceleration allows for more efficient shooting.
12 MP Stills
The Mavic Air’s onboard camera integrates a 1/2.3" 12-megapixel CMOS sensor and an f/2.8 lens with a 35-mm equivalent focal length of 24 mm to shoot high-quality photos and videos.
8 GB Internal Storage
In addition to a Micro SD card slot, 8 GB of internal storage let you save photos and videos directly to the aircraft and export files through its USB 3.0 Type-C port.
3D Foldable Design
As tall and wide as a smartphone when folded, the Mavic Air is an ultraportable drone that stretches the boundaries of what's possible for a device its size.
Foldable Remote Controller
The dedicated remote controller uses a foldable, low-profile, ergonomic design to hold your smartphone for maximum convenience. Detachable control sticks store inside the remote controller to pack more comfortably on the go.
ActiveTrack
ActiveTrack can sense up to 16 selectable subjects simultaneously,2 letting you choose the right tracking subject. With higher tracking precision and broader scenario applications, ActiveTrack follows targets even when they're running, jumping, or cycling.
TapFly
If you want to focus on just your shot, select TapFly in DJI GO 4, which lets you fly wherever you tap on your mobile device screen. TapFly works in Forward, Backward, Free, and Coordinate modes, and you can adjust flight speed to suit all your aerial needs.
FlightAutonomy 2.0
Using advanced VIO technology, the powerful sensor system in FlightAutonomy 2.0 consists of a primary gimbal camera, forward, backward, and downward dual-vision sensors, downward infrared sensing system, IMU redundancies, and a group of computing cores. Together, they collect and transmit information from the surrounding environment to the high-performance processor for more precise hovering and better flight performance. Advanced Pilot Assistance Systems (APAS) allow the aircraft to bypass obstacles in front of and behind it actively. Your grand adventures of discovery have never been so safe and easy.
Fly More Combo - Box Contents
Drone
Controller
Propellers (Pair) x 4
Propeller Guards Set
Charger
Power Cable
Battery Charging Hub
Battery to Power Bank Adaptor
RC Cable - Lightning Connector, microUSB, USB Type-C
USB Adaptor
Carry Case
Travel Bag
Gimbal Protector
RC Cable Slider Large and Small
Spare Control Sticks (Pair)
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
  1. Always keep your drone in sight
  2. Stay below 400ft (120m) to comply with the dronecode
  3. Every time you fly your drone you must follow the manufacturer’s instructions
  4. Keep the right distance from people and property – People & Properties 150ft (50m), Crowds and built up areas 500ft (150m)
  5. You are legally responsible for each flight
  6. Stay well away from aircraft, airports and airfields. If your drone endangers the safety of an aircraft it is a criminal offence.
For more information visit: https://dronesafe.uk/drone-code/
Product Description DJI Mavic Air Fly More Combo - drone
Product Type Drone
Category Vehicles - drones
Compatibility iPhone, iPad, Android phone
Camera Included - 12 Megapixel
Max Speed 68.4 kilometers per hour
Navigation GPS/GLONASS receiver
Interface Wi-Fi
Colour Onyx black
Width 18.4 cm
Depth 16.8 cm
Height 6.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DJI Mavic Air Fly More...
£949.00
