Looking for a phone that makes everyday calling and texting simple, with direct keys for even easier functionality? The Doro 1370 offers you all this plus a torch, a camera and more.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | DORO 1370 - black - feature phone - 16 MB - GSM | Product Type | Feature phone | Display | LCD display - 240 x 320 pixels - 2.4" - TFT | Features | FM radio, LED flashlight | Memory | RAM 8 MB / 16 MB | Supported Memory Card | microSD slot | Main Camera | 3 Megapixel | Service Provider | Not specified | Form Factor | Bar | SIM Card | Single-SIM - micro SIM | Wireless Interface | Bluetooth | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack | Talk Time | Up to 420 minutes | Standby Time | Up to 530 hours | Colour | Black | Dimensions (WxDxH) | 61.5 mm x 12.6 mm x 125 mm | Weight | 106 g | SAR | 1.479 W/kg (body), 0.392 W/kg (head) |
General | |
Form Factor | Bar |
Integrated Components | FM radio, LED flashlight |
Width | 61.5 mm |
Depth | 12.6 mm |
Height | 125 mm |
Weight | 106 g |
Body Colour | Black |
SAR Value | 1.479 W/kg (body), 0.392 W/kg (head) |
Cellular | |
Technology | GSM |
SIM Card Type | Micro SIM |
SIM Card Qty | Single-SIM |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS |
2G Band | 900 GSM, 1800 GSM, 1900 GSM |
Wireless Interface | Bluetooth 3.0 |
Phone Features | |
Phone Functions | Speakerphone, call timer, conference call, flight mode, vibrating alert |
Memory | |
RAM | 8 MB |
Internal Memory Capacity | 16 MB |
Supported Flash Memory Cards | microSD |
Main Camera | |
Sensor Resolution | 3 Megapixel |
Light Source | LED light |
Display | |
Type | LCD display |
Technology | TFT |
Diagonal Size | 2.4" |
Display Resolution | 240 x 320 pixels |
Connections | |
Connector Type | Headset jack - mini-phone 3.5mm |
Battery | |
Technology | Lithium Ion |
Capacity | 1000 mAh |
Talk Time | 420 minutes |
Standby Time | 530 hours |
Run Time Details | Talk: up to 420 min , Standby: up to 530 hrs |
Miscellaneous | |
Compliant Standards | HAC (Hearing Aid Compatible) |
Included Accessories | Headset, power adapter |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
