The Doro 780X targets fragile seniors with severe handling problems. A senior dependent on a robust and extremely easy to use mobile that will help them out throughout the day, with the added peace of mind provided by Doro design and services.
Call the people you rely on in a simple press of a button, and feel even safer thanks to a safety timer function for special situations, alarm button, GPS localization and remote management.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | DORO 780X IUP - black, white - 4G feature phone - 4 GB - GSM | Product Type | 4G feature phone | Display | 320 x 240 pixels - 2.8" | Features | LED flashlight | Processor | MediaTek MT6731V/ZA | Memory | RAM 512 MB / 4 GB | Supported Memory Card | microSDXC slot | Service Provider | Not specified | Form Factor | Bar | SIM Card | Dual-SIM - micro SIM | Wireless Interface | Wi-Fi, Bluetooth | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, Micro-USB | Talk Time | Up to 480 minutes | Standby Time | Up to 330 hours | Colour | Black, white | Dimensions (WxDxH) | 60 mm x 13 mm x 138 mm | Weight | 117 g | SAR | 0.785 W/kg (head), 2.651 W/kg (limb), 1.503 W/kg (body) |
General | |
Product Type | Feature phone |
Form Factor | Bar - Yes |
Integrated Components | LED flashlight |
Width | 60 mm |
Depth | 13 mm |
Height | 138 mm |
Weight | 117 g |
Body Colour | Black, white |
SAR Value | 0.785 W/kg (head), 2.651 W/kg (limb), 1.503 W/kg (body) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Navigation | A-GPS |
SIM Card Type | Micro SIM |
SIM Card Qty | Dual-SIM |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, HSPA+, LTE, VoLTE |
2G Band | 900 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 2, Band 8 |
3G UMTS Frequency | 2100, 1900, 900 |
4G LTE Band | Band 1, Band 3, Band 7, Band 8, Band 20 |
4G LTE Frequency | FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD |
Wireless Interface | Wi-Fi, Bluetooth 4.2 |
Phone Features | |
Additional Features | SOS button, HD Voice, ICE (In Case of Emergency) function, position monitoring, inactivity monitoring, recall alarm request |
Processor | |
Type | MediaTek |
Processor Number | MT6731V/ZA |
Memory | |
RAM | 512 MB |
Internal Memory Capacity | 4 GB |
Supported Flash Memory Cards | microSDHC, microSD, microSDXC |
Display | |
Diagonal Size | 2.8" |
Display Resolution | 320 x 240 pixels |
Display Format | QVGA |
Connections | |
Connector Type | Headset jack - mini-phone 3.5mm , Micro-USB |
Battery | |
Technology | Lithium Ion |
Capacity | 1600 mAh |
Talk Time | 480 minutes |
Standby Time | 330 hours |
Run Time Details | Talk: up to 480 min , Standby: up to 330 hrs |
Miscellaneous | |
Compliant Standards | IP54, HAC (Hearing Aid Compatible) |
Included Accessories | Charging stand |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
