DrayTek VigorAP 920RPD 802.11ac Access Point with PoE Passt...
DrayTek
VigorAP 920RPD 802.11ac Access Point with PoE Passthrough
£398.66
Delivery:
Standard: 1-3 working days
Key features
  • IP67 rated dust & water resistant
  • Concurrent dual-band 802.11ac Wave 2 with 2x2 MU-MIMO
  • Delivers data rate of up to 867 Mbps in the 5GHz band and 400 Mbps in the 2.4GHz band
  • 1 Gigabit Ethernet LAN ports with PoE In support
  • 1 Gigabit Ethernet LAN ports with PoE Out support
  • Internal directional antenna for Point-to-Point deployment
  • Point-to-Point Connectivity up to 3km (RPD model)
  • 4 SSIDs with unique VLAN setting, Access Control, and Bandwidth Limit policies
  • Features AirTime Fairness and Band Steering for better Wi-Fi user experience
  • Built-in RADIUS server for 802.1x authentication
  • Improve roaming experience by Fast Roaming & AP-assisted Roaming
  • Provide multiple operating modes - AP, Bridge, WDS, and Universal Repeater
  • Support both stand-alone and controller-based setup
  • Type: Radio access point
  • Connectivity: Wireless
  • Protocol: IEEE 802.11a, IEEE 802.11ac Wave 2, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock
Product codes
Marketing description is not available.
Product Description Draytek VigorAP 920RPD - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band 2.4 GHz, 5 GHz
Performance Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 867 Mbps
Capacity Wireless clients per Wi-Fi radio: 128 , SSIDs per radio: 4
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 16 cm x 8 cm x 25.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek VigorAP 920R...
£398.66
