DrayTek ANT-2520 10dB Unidirectional Antenna (Single)
£21.00
Delivery:
Key features
  • High-gain dual-band antenna
  • Unidirectional beam pattern
  • Improved data throughput at further distances
Product codes
Draytek ANT-2520 is a dual-band indoor directional patch antenna. It is used for normal indoor point-to-point wireless connection applications. ANT-2520 is designed to connect with most wireless devices that use a detachable antenna. Simply unscrew the existing antenna on your device, connect to the Draytek high-gain antenna and enjoy the benefits of wireless network.
Product Description Draytek ANT-2520 - antenna
Product Type Antenna
Dimensions (WxDxH) 6.5 cm x 1.8 cm x 16.5 cm
Colour Black
Form Factor Plate
Intended For Wi-Fi
Aerial Placing / Mounting Indoor
Compatibility 802.11 a/b/g/n/ac
Frequency Range 2.4 - 2.5 GHz, 5.15 - 5.85 GHz
Gain 10 dBi (for 5 GHz), 7.5 dBi (for 2.4 GHz)
Directivity Directional
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek ANT-2520 10dB...
£21.00
