Marketing description is not available.
Product Description | Draytek Vigor 2763ac - wireless router - DSL modem - 802.11a/b/g/n/ac Wave 2 - desktop, wall-mountable | Device Type | Wireless router - DSL modem - 4-port switch (integrated) | Enclosure Type | Desktop, wall-mountable | Digital Signaling Protocol | H.323, ADSL, SIP, ADSL2, ADSL2+, VDSL2 | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz / 5 GHz | Performance | VPN throughput (256-bit AES IPSec): 200 Mbps , VPN throughput (SSL): 80 Mbps , NAT throughput: 700 Mbps , NAT throughput (with VDSL2): 100 Mbps , NAT throughput with hardware acceleration: 950 Mbps , NAT throughput without hardware acceleration: 700 Mbps , Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 866 Mbps | Capacity | Priority QoS queues: 4 , Concurrent VPN tunnels: 2 , NAT sessions: 50000 , DHCP pool: 253 , SSIDs per radio: 4 , VLANs supported: 8 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, FTP, DHCP, Bonjour, DHCPv6, RTSP, IPv4, IPv6 | Routing Protocol | MPOA, static IPv4 routing, static IPv6 routing | Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, TR-069, Syslog | VoIP Protocols | H.323, SIP | Features | IGMP snooping, DoS attack prevention, content filtering, port mirroring, E-mail alert, LAN-to-LAN bridging, Wi-Fi Multimedia (WMM) support, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SMS alert, reset button, DNS server, port triggering, 3G/4G USB Dongle Support, Transmit Beam-forming (TxBF) ready, dual-stream (2x2), IGMP proxy, 802.1x authentication, Type of Service (ToS), automated backup scheduling, MU-MIMO technology, fast leave, Inter-VLAN Routing, L2TP over IPSec, black list, white list, DSCP based ToS, wireless access control, DNSSEC support, Point-to-Point Protocol (PPP), IPTV support, Extensible Authentication Protocol over LAN (EAPOL), OpenVPN pass-through, Brute Force Protection, SIP ALG (Application Layer Gateway), DrayDDNS, WAN Budget, Wi-Fi on/off button, DSL mode, USB backup, ping detect, ARP detect, dynamic DNS, Full Feature-set Hardware Acceleration, 2-Level Administration Privilege, Teleworker-to-LAN bridging, ISP Video support, NAT port redirection, DMZ host, spoofing defence, user-based Time Quota, IP-based Firewall Policy | Compliant Standards | IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11n, UPnP, ITU-T G.993.1, ITU-T G.993.2, ITU-T G.997.1, IEEE 802.11ac Wave 2 | Power | AC 100-240 V / DC 12 V | Dimensions (WxDxH) | 20.7 cm x 13.1 cm x 4.2 cm | Localisation | United Kingdom, Ireland | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Wireless router - 4-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | DES, Triple DES, MPPE, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, WEP, WPS, WPA3, IKEv1, SHA-256 |
Authentication Method | RADIUS, internal user database, Mobile One Time Password (mOTP) |
Wi-Fi Rating | AC1300 |
Compliant Standards | IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11n, UPnP, ITU-T G.993.1, ITU-T G.993.2, ITU-T G.997.1, IEEE 802.11ac Wave 2, TOTP |
Built-in Devices | Led panel |
Status Indicators | WAN, LAN, USB, 5 GHz, 2.4 GHz, QoS |
Line Properties | |
Framing Format | ANSI T1.413i2 |
Communications | |
Type | DSL modem |
Protocols & Specifications | ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex J, ITU G.992.3 Annex J |
Max Transfer Rate | 300 Mbps |
IP Telephony | |
Expansion / Connectivity | |
Interfaces | LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , Antenna: 2 x |
Aerial | |
Aerial | External detachable |
Antenna Qty | 2 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100-240 V / DC 12 V |
Power Consumption Operational | 21 Watt |
Miscellaneous | |
Included Accessories | 2 x WiFi aerials |
Cables Included | 1 x network cable - 2 m |
Mounting Kit | Included |
Dimensions & Weight | |
Width | 20.7 cm |
Depth | 13.1 cm |
Height | 4.2 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
