DrayTek DrayTek Vigor 2926n Dual-WAN/Wireless Router
£210.32
Delivery:
Key features
  • 2 Ethernet WAN for load balancing or failover
  • Built-in 3G/4G/LTE cellular connectivity
  • Built-in 802.11ac Wave 2 dual-band Wi-Fi
  • 1 USB port for 3G/4G modem or extra storage
  • 50 simultaneous VPN tunnels
  • SPI firewall with content filtering by url keyword, category, and apps
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b + 2 more
Product codes
Vigor 2926 Series Ethernet Router Firewall & Load-Balancer
The Vigor 2926 series is our dual-Ethernet WAN firewall for load-balancing or failover. It's also a fully featured firewall, VPN concentrator and content filtering device.
This latest router series includes support for professional features such as VLAN tagging, Gigabit Ethernet, built-in wireless LAN (Vigor 2926n or Vigor 2926ac). An alternative WAN connectivity is by a USB 3G/4G/LTE cellular modem which can be your primary WAN feed, backup or load-balanced with your fixed line.
A 5-port Gigabit Ethernet switch on the LAN side provides high speed connectivity for your server, other local PCs or for uplink to a larger Ethernet switch. Comprehensive security features include content filtering, web application controls and an object based firewall management system. Port 5 is switchable with 'WAN2' to use it as an Ethernet WAN port instead of a LAN port (requires f/w 3.8.8 or later, otherwise 5th Ethernet port is for WAN2 only.)
Robust & Comprehensive Firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorised remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organisations. The Vigor 2926 also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to LAN/VPN.
Central Management with VigorACS
The Vigor 2926 series (along with most other DrayTek routers, Access points and switches) can be centrally managed by our VigorACS central management platform. This scalable solution provides visibility, control and reporting of your entire DrayTek product estate, ideal for dealers/SIs manageing customers' devices or any user who wants to know what's going on with their devices. VigorACS also provides features like automated/bulk firmware updates, VPN management and alarms for connectivity or other issues.
Web Content Filtering
The content control features of the Vigor 2926 series allows you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or universal and according to time schedules. Content filtering can also block sites using HTTPS/SSL where URLs are encrypted (and normal routers cannot block).
User Management/Authentication
The Vigor 2926 has built-in user management which allows you to provide conditional internet access with Time and Data usage quotas to different users, based on their own unique login (stored in the router, or on an external Radius server).
Rack Mounting Kit
The RM1 Rackmount Bracket enables you to fit any Vigor 2926 series router into a standard 19" rack or cabinet. The bracket takes up one rack slot (1U) and includes a cable retainer at the back to keep the power cord captive. The front mounted sockets of the router remain fully accessible. For wireless models, we then recommend extension aerials (or aerial extensions).
USB Port for Ad-Hoc Storage / Logging
The Vigor 2926's USB port can also be used to add storage memory to the unit in the form of a USB memory key (as shown right). The Vigor 2926 then provides FTP access file uploading/downloading which can be from the local LAN or from anywhere on the Internet - ideal for a simple to deploy file depository. If you do have a USB memory key connected, you can also have the router save it's system logs (syslog) to that memory instead of to a connecting computer; useful for technical personnel (SysAdmins).
Product Description Draytek Vigor 2926n - wireless router - 802.11b/g/n - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Capacity VPN tunnels: 50 , Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25
Network / Transport Protocol PPTP, L2TP, NTP, IPSec, PPPoE, DNS, DHCPv6
Routing Protocol RIP-2, static IP routing
Remote Management Protocol SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
Features DMZ port, IGMP snooping, Syslog support, DoS attack prevention, content filtering, DiffServ support, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), dual WAN connection, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, Multiple SSID support, SMS alert, hidden SSID, DNS proxy, Bandwidth-On-Demand (BOD), reset button, IPv4 support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, DHCP client, tagged VLAN, IM/P2P filter, DNS caching, Content Security Management (CSM), Type of Service (ToS), DiffServ Code Point (DSCP) support
Compliant Standards IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
Dimensions (WxDxH) 16.5 cm x 24.1 cm x 4.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek DrayTek Vigor...
£210.32
