DrayTek USB Thermometer (for V2860/V3900 etc.)
£24.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Alarm max/min thresholds
  • Continuous reporting to syslog
  • Syslog reporting
  • Email and SMS reporting on threshold breach
  • Stock Status: In Stock
Product codes
With the installation of this USB thermometer, compatible Vigor routers can take continuous temperature readings from the vicinity of the router. This USB thermometer connects to the router's USB port either directly or placed nearby using the supplied 1 Metre USB extension cable.
You can log into the router at any time and see the current temperature and the previous 24-hour's high/low as well as graphs. You can set thresholds so that if it gets too hot or too cold at the sensor, you'll receive an email or SMS (text message).
Typical applications will be to report the temperature in your comms/IT cabinet or room, but also the general office temperature, depending on the placement of the temperature 'dongle'. USB typically allows a maximum cable length of up to 3M. Note : Exact facilities vary by router model.
Product Description Draytek USB Thermometer - digital thermometer
Product Type Digital thermometer
Package Content USB cable
Weight 45 g
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek USB Thermomete...
£24.00
