We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Vigor2765 Series is a 35b Supervectoring VDSL modem, a firewall, and a VPN router. The router has 4x GbE LAN port, one of which is switchable to be a backup WAN interface. It's highly configurable for an abundance of features including web content filtering, bandwidth limit, QoS and lots more, perfect for professional users who would like to take full control of the network. The series includes models with built-in 11ac Wave2 Wi-Fi.
Product Description | Draytek Vigor 2765Vac - wireless router - DSL modem - 802.11a/b/g/n/ac Wave 2 - desktop | Device Type | Wireless router - DSL modem | Enclosure Type | Desktop | Digital Signaling Protocol | ADSL, VDSL, ADSL2, ADSL2+, VDSL2, Vplus 35b | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz / 5 GHz | Performance | VPN throughput (256-bit AES IPSec): 200 Mbps , VPN throughput (SSL): 80 Mbps , NAT throughput: 600 Mbps | Capacity | VLANs supported: 8 , Concurrent VPN tunnels: 2 , NAT sessions: 50000 , SSIDs per radio: 4 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6 | Routing Protocol | RIP, MPOA, static IPv4 routing, static IPv6 routing, policy-based routing (PBR) | Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069 | VoIP Functionality | VoIP phone adapter | VoIP Protocols | H.323, SIP | Telephony Interfaces | 2 phone (FXS) | Features | Firewall protection, VPN support, ARP support, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, print server, IPv6 support, VPN passthrough, URL filtering, LAN-to-LAN bridging, Wi-Fi Multimedia (WMM) support, file sharing, Access Control List (ACL) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), DHCP server, SMS alert, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, tagged VLAN, IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support, MU-MIMO technology, keyword filtering, beamforming technology, failover protection, Web Filtering, DMZ support, VLAN Tagging, port-based VLAN, DSCP based ToS, DynDNS, 2x2 MIMO technology, WPS button, Brute Force Protection | Compliant Standards | IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac Wave 2 | Dimensions (WxDxH) | 20.7 cm x 13.1 cm x 4.2 cm | Weight | 500 g | Localisation | United Kingdom, Ireland |
General | |
Device Type | Wireless router |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | DES, Triple DES, MD5, MPPE, SSL, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK, IKEv2, 256-bit SHA, WEP |
Authentication Method | RADIUS, X.509 certificates, internal user database, XAUTH authentication |
Compliant Standards | IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac Wave 2, FCC |
Built-in Devices | Led panel |
Line Properties | |
Framing Format | ANSI T1.413 |
Communications | |
Type | DSL modem |
Protocols & Specifications | ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.5, ITU G.993.1, ITU G.993.2, ITU G.992.3 |
Max Transfer Rate | 300 Mbps |
IP Telephony | |
Expansion / Connectivity | |
Interfaces | LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , Phone line: 2 x FXS - RJ-11 , Antenna: 2 x |
Aerial | |
Aerial | External detachable |
Antenna Qty | 2 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 19 Watt |
Miscellaneous | |
Included Accessories | 2 x WiFi aerials |
Cables Included | 1 x modem cable , 1 x network cable |
Dimensions & Weight | |
Width | 20.7 cm |
Depth | 13.1 cm |
Height | 4.2 cm |
Weight | 500 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
