DrayTek Vigor 2862 Series ADSL/VDSL Router with 802.11ac Wire...
DrayTek Vigor 2862 Series ADSL/VDSL Router with 802.11ac Wireless
£259.35
44 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Runs on either ADSL or VDSL
  • Robust & comprehensive firewall
  • IPv6 - next generation Internet routing
  • Web content filtering
  • WAN Load Balancing & backup
  • Type: Wireless router
  • Connection Type: ADSL or VDSL
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac + 3 more
  • Speed: 2033Mbps
  • Stock Status: In Stock
Product codes
The Vigor 2862 series is their flagship router/firewall. As well as ADSL/VDSL support, alternative WAN ports can instead provide connectivity to Ethenet feeds (Gigabit WAN2 is switchable with LAN Port 5), secondary xDSL modems or a 3G/4G cellular service using a supported USB adapter. These multiple LAN feeds can be combined for failover or load-balancing.
This router series includes support for other professional features such as VLAN tagging, QoS (Quality of Service Assurance), High Availability, DNS Filter, Policy Based Routing, and User Access Control. Hotspot features with customisable branding and wording which can be applied to guest network VLANs & SSIDs. If you deploy DrayTek Wireless Access Points, the Vigor 2862 can act as the Central Management controller (click on any of those links for an explanation of each feature).
A 5-port Gigabit Ethernet switch on the LAN side provides high speed connectivity for your server, other local PCs or for uplink to a larger Ethernet switch. Comprehensive security features include content filtering, web application controls and an object based firewall management system. Port 5 is switchable with "WAN2" to use it as an Ethernet WAN port instead of a LAN port.
Product Description Draytek Vigor 2862ac - wireless router - DSL modem - 802.11b/g/n/ac - desktop
Device Type Wireless router - DSL modem - 5-port switch (integrated)
Enclosure Type Desktop
Digital Signaling Protocol ADSL2, ADSL2+, READSL, VDSL2
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 2033 Mbps
Performance Firewall throughput: 400 Mbps , VPN throughput (IPSec): 60 Mbps
Network / Transport Protocol PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, AAL5, FTP, DHCP, DNS, DDNS
Routing Protocol RIP-2, static IP routing, RIPng
Remote Management Protocol SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
Features Firewall protection, NAT support, VPN support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, Multiple SSID support, hidden SSID, Bandwidth-On-Demand (BOD), DHCP relay, 3G/4G USB Dongle Support, DHCP client, Management Information Base (MIB), 4T4R MIMO technology, tagged VLAN, DNS caching, Content Security Management (CSM), Type of Service (ToS), DiffServ Code Point (DSCP) support, beamforming technology, Airtime Fairness, congestion avoidance (based on IP precedence/DSCP-based WRED)
Compliant Standards IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ac, IEEE 802.11e, IEEE 802.11n
Power AC 230V
Dimensions (WxDxH) 24.096 cm x 16.507 cm x 4.396 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek Vigor 2862 Ser...
£259.35
