DrayTek Vigor 2862 Series ADSL/VDSL Router with 802.11n 3G/4G...
DrayTek Vigor 2862 Series ADSL/VDSL Router with 802.11n 3G/4G/LTE
£385.81
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Standard-size SIM slot
  • Sending/receiving of SMS messages to web interface
  • Status reports & alerts via SMS, and SMS-initiated reboot
  • Standard size SIM slot on with fixed cover
  • Unlocked to any network
  • 3G data modes - GPRS/HSDPA/HSPA+
Product codes
The embedded 4G/LTE connectivity provides a self-contained solution as opposed to having to add external/USB modems to your router. A standard SIM slot on the back of the router is secured with a cover to prevent accidental removal (you can leave the cover off if you need easy access). As well as connectivity to the 4G (LTE) networks, the Vigor 2862L series provides backward compatibility to 3G networks for areas or networks where 4G isn't available. Full function MS message operation also provides additional functionality and control.
Draytek Vigor 2862LN - wireless router - DSL/WWAN - 802.11b/g/n - desktop
Wireless router - DSL modem / wireless cellular modem - 5-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL, VDSL2
Cellular Protocol
GSM, GPRS, UMTS, HSDPA, HSPA+, LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
Firewall throughput: 400 Mbps , VPN throughput (IPSec): 60 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI, TR-069, TR-104
Firewall protection, NAT support, VPN support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, Multiple SSID support, hidden SSID, Bandwidth-On-Demand (BOD), DHCP relay, 3G/4G USB Dongle Support, DHCP client, Management Information Base (MIB), 4T4R MIMO technology, tagged VLAN, DNS caching, Content Security Management (CSM), Type of Service (ToS), DiffServ Code Point (DSCP) support, beamforming technology, Airtime Fairness, congestion avoidance (based on IP precedence/DSCP-based WRED)
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n
AC 230V
24.096 cm x 16.507 cm x 4.396 cm
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek Vigor 2862 Ser...
£385.81
