Marketing description is not available.
Product Description | Draytek Vigor 2865Lac - router - DSL/WWAN - 802.11a/b/g/n/ac Wave 2 - desktop | Device Type | Router - DSL modem / wireless cellular modem - 6-port switch (integrated) | Enclosure Type | Desktop | Digital Signaling Protocol | ADSL, VDSL, ADSL2, ADSL2+, VDSL2, Vplus 35b | Mobile Communication Protocol | LTE | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz / 5 GHz | Capacity | Concurrent VPN tunnels: 32 , NAT sessions: 50000 , Concurrent SSL VPN tunnels: 16 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6 | Routing Protocol | RIP, BGP, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR) | Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069 | VoIP Protocols | H.323, SIP | Features | Firewall protection, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, Wireless Distribution System (WDS) support, URL filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, SMS alert, hidden SSID, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, IGMP proxy, 802.1x authentication, Type of Service (ToS), Push Button Configuration (PBC), L2TP passthrough, band steering, WDS bridge, Web Filtering, IGMP fast leave, Airtime Fairness, 2x2 MU-MIMO technology, L2TP over IPSec, client isolation, DMZ support, VLAN Tagging, port-based VLAN, port-based QoS, WDS repeater mode, multiple PVC support, broadcast threshold, DNS filtering, 2x2 MIMO technology, DNSSEC support, WLAN scheduling, DSCP based QoS, Brute Force Protection | Compliant Standards | IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.1x, UPnP | Dimensions (WxDxH) | 24.1 cm x 16.6 cm x 4.6 cm | Localisation | United Kingdom, Ireland |
General | |
Device Type | Router - 6-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | DES, Triple DES, MPPE, AES, SSL, SHA-1, WPA, WPA2, IKEv2, 256-bit SHA, WEP |
Authentication Method | RADIUS, X.509 certificates, TACACS+, LDAP, internal user database, XAUTH authentication |
Status Indicators | WAN, DMZ, link/activity, USB, DSL, 5 GHz, 2.4 GHz, QoS |
Line Properties | |
Framing Format | ANSI T1.413 |
Communications | |
Type | DSL modem / wireless cellular modem |
Protocols & Specifications | ITU G.992.1 (G.DMT), ITU G.992.5, ITU G.993.2, ITU G.993.5, ITU G.992.3 |
Max Transfer Rate | 300 Mbps |
IP Telephony | |
Expansion / Connectivity | |
Interfaces | LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A |
Expansion Slots | 2 SIM |
Aerial | |
Aerial | External detachable |
Antenna Qty | 2 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x modem cable |
Dimensions & Weight | |
Width | 24.1 cm |
Depth | 16.6 cm |
Height | 4.6 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
