DrayTek Vigor 2927AC WiFi Router
£303.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Dual-WAN for load-balancing or redundancy
  • Embedded Cat.6 LTE/4G/3G cellular connectivity (L model)
  • AX3000 Wi-Fi 6 dual-band wireless interface (ax model)
  • 50 simultaneous VPN tunnels, up to 25 SSL VPN
  • SPI firewall and content filtering
  • Central management for VigorAP & VigorSwitch
  • Type: Wireless router
  • Standards: Fast Ethernet, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a + 4 more
Product codes
Marketing description is not available.
Product Description Draytek Vigor 2927ac - wireless router - 802.11a/b/g/n/ac Wave 2 - desktop
Device Type Wireless router - 6-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band 2.4 GHz / 5 GHz
Performance VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (IPSec): 800 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput: 800 Mbps , Maximum data rate (5 GHz): 866 Mbps , Maximum data rate (2.4 GHz): 400 Mbps
Capacity Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000 , SSIDs per radio: 4 , SIP registrars: 12
Network / Transport Protocol PPTP, L2TP, IPSec, PPPoE, DNS, DDNS, DHCPv6, IPv4, IPv6
Routing Protocol RIP-1, RIP-2, BGP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), RIPng
Remote Management Protocol SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH, TR-069
Features Firewall protection, NAT support, VPN support, load balancing, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, print server, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, wall mountable, LAN-to-LAN bridging, tunnelling, Wi-Fi Multimedia (WMM) support, file sharing, Quality of Service (QoS), dual WAN connection, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, reset button, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, DHCP client, IGMP proxy, MU-MIMO technology, beamforming technology, band steering, IGMP fast leave, Airtime Fairness, DMZ support, VLAN Tagging, port-based VLAN, DNSSEC support, DHCP over IPSec, Point-to-Point Protocol (PPP), DSCP based QoS, Brute Force Protection
Compliant Standards IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
Power AC 230V
Dimensions (WxDxH) 24.1 cm x 16.5 cm x 4.4 cm
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£303.22
