Marketing description is not available.
Product Description | Draytek Vigor 2927LAC - wireless router - WWAN - 802.11a/b/g/n/ac Wave 2 - desktop | Device Type | Wireless router - wireless cellular modem - 6-port switch (integrated) | Enclosure Type | Desktop | Mobile Communication Protocol | HSPA+, LTE | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz / 5 GHz | Performance | VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput: 800 Mbps | Capacity | Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, DHCP, DNS, DDNS, DHCPv6, IPv4, IPv6 | Routing Protocol | RIP, BGP, IGMPv2, IGMP, static IP routing, IGMPv3, policy-based routing (PBR) | Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, TR-104 | Features | NAT support, VPN support, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, E-mail alert, print server, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, DDos attack prevention, wall mountable, tunnelling, Wi-Fi Multimedia (WMM) support, file sharing, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), roaming function, WAN failover, DHCP server, Multiple SSID support, hidden SSID, reset button, Wireless Client Mode, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, DHCP client, tagged VLAN, IGMP proxy, Management Information Base (MIB) II, DMZ support, VLAN Tagging, port-based VLAN, Wireless Mesh support, WLAN/WPS button, 2x2 MIMO technology, 4x4 MIMO technology, DSCP based QoS | Compliant Standards | IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac Wave 2 | Power | AC 230V | Dimensions (WxDxH) | 24.1 cm x 16.5 cm x 4.4 cm | Localisation | United Kingdom |
General | |
Device Type | Wireless router - 6-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | DES, Triple DES, MPPE, 128-bit WEP, 64-bit WEP, SSL, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, IKEv1, SHA-256 |
Authentication Method | RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS+, LDAP |
Wi-Fi Rating | AC1300 |
Built-in Devices | Led panel |
Status Indicators | Active, WAN, DMZ, USB, LTE, 5 GHz, 2.4 GHz, QoS |
Communications | |
Type | Wireless cellular modem |
Max Transfer Rate | 300 Mbps |
Expansion / Connectivity | |
Interfaces | LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A , Antenna: 4 x |
Expansion Slots | 1 (total) / 1 (free) x SIM |
Power | |
Power Device | External power adapter |
Voltage Required | AC 230V |
Miscellaneous | |
Included Accessories | 2 aerial magnetic extension bases, 2 x WiFi aerials, 2 x LTE aerials |
Cables Included | 2 x aerial extension cable - 1 m |
Dimensions & Weight | |
Width | 24.1 cm |
Depth | 16.5 cm |
Height | 4.4 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
