DrayTek Vigor 2962 Dual-WAN Firewall Router
£406.45
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Load balancing
  • VPN (Virtual Private Network)
  • SSL VPN
  • VPN Matcher
  • Firewall and Content Filter
  • VoIP Friendly
  • Type: Router
  • Connection Type: WAN/LAN
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
  • Rackmount or External: Rack-mountable
Product codes
Marketing description is not available.
Product Description Draytek Vigor 2962 - router - desktop, rack-mountable
Device Type Router - 4-port switch (integrated)
Enclosure Type Desktop, rack-mountable
Digital Signaling Protocol H.323, SIP
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Performance NAT throughput with hardware acceleration: 2.2 Gbps , VPN throughput (256-bit AES IPSec): 900 Mbps , VPN throughput (SSL): 650 Mbps
Capacity Concurrent VPN tunnels: 200 , NAT sessions: 300000 , Concurrent SSL VPN tunnels: 200 , 802.1q virtual interfaces (VLANs): 50
Network / Transport Protocol PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, DDNS, DHCPv6, RTSP
Routing Protocol OSPF, RIP-1, RIP-2, BGP, GRE, RIPng
Remote Management Protocol SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2, TR-069
VoIP Protocols H.323, SIP
Features NAT support, load balancing, Syslog support, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, URL filtering, firmware upgradable, LAN-to-LAN bridging, Access Control List (ACL) support, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications, IPSec NAT-Traversal (NAT-T), DHCP server, SMS alert, bandwidth control, IPv4 support, DNS server, port triggering, anti-spoofing protection, IP-MAC binding, application filtering, tagged VLAN, IGMP proxy, 802.1x authentication, Type of Service (ToS), Web Filtering, Denial of Service (DoS) protection, L2TP over IPSec, DMZ support, port-based VLAN, One-Time Password (OTP), Bandwidth Limiter, multiple PVC support, broadcast threshold, DNS filtering, DNSSEC support, Point-to-Point Protocol (PPP), PIN code authentication, DSCP based QoS, Brute Force Protection
Compliant Standards IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
Power AC 120/230 V
Dimensions (WxDxH) 27.3 cm x 17.1 cm x 4.5 cm
Weight 1.3 kg
Localisation United Kingdom, Ireland
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£406.45
