DrayTek Vigor 3910 Multi-WAN router
£766.45
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Powerful enterprise Internet gateway
  • High-performance VPN concentrator
  • Flexible WAN architecture
  • High availability
  • Manage multiple networks
  • Type: Router
  • Connection Type: WAN/LAN
  • Standards: Ethernet, Gigabit Ethernet, Fast Ethernet, PPP + 2 more
  • Rackmount or External: Rack-mountable
Product codes
The DrayTek Vigor 3910 is a multi-WAN router and an ideal VPN concentrator, delivering high performance to meet the current and future bandwidth demands of complex networks. The Vigor 3910 combines performance, capacity and flexibility, with ease of use and a comprehensive feature set.
Product Description Draytek Vigor 3910 - router - rack-mountable
Device Type Router
Enclosure Type Rack-mountable - 1U
WAN Ports Qty 8
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, PPP, 10 Gigabit Ethernet, 2.5 Gigabit Ethernet
Performance NAT throughput: 9 Gbps , VPN throughput (IPSec): 3.3 Gbps , VPN throughput (SSL): 1 Gbps
Capacity Concurrent VPN tunnels: 500 , Virtual interfaces (VLANs): 50 , NAT sessions: 150000 , Dynamic IP pool: 4093 , Concurrent SSL VPN tunnels: 200
Network / Transport Protocol PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol RIP-1, RIP-2, BGP, IGMP, OSPFv2, static IP routing, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), RIPng
Remote Management Protocol SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
VoIP Protocols H.323, SIP
Features Firewall protection, NAT support, VPN support, load balancing, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, High Availability, URL filtering, IP address filtering, firmware upgradable, file sharing, Access Control List (ACL) support, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications, IPSec NAT-Traversal (NAT-T), DHCP server, SMS alert, reset button, IPv4 support, DNS server, port triggering, anti-spoofing protection, IP-MAC binding, IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support, VPN concentrator, failover protection, Web Filtering, Application Level Gateways (ALGs), DMZ support, VLAN Tagging, port-based VLAN, Bandwidth Limiter, DynDNS, Brute Force Protection
Compliant Standards IEEE 802.1Q, IEEE 802.1p, X.509, UPnP
Power AC 230V
Dimensions (WxDxH) 44.3 cm x 28.5 cm x 4.5 cm
Weight 3.23 kg
Localisation United Kingdom, Ireland
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£766.45
