Marketing description is not available.
Product Description | Draytek VigorAP 1000C - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | Wall / ceiling mountable | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 866 Mbps | Included Accessories | Ceiling mounting kit | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 17.6 cm x 17.6 cm x 3 cm | Weight | 500 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 17.6 cm |
Depth | 17.6 cm |
Height | 3 cm |
Weight | 500 g |
Networking | |
Connectivity Technology | Wireless |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069 |
Features | Syslog support, MAC address filtering, DFS support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID, temperature / humidity sensor, reset button, DHCP relay, band steering, Fast Roaming, Airtime Fairness, client isolation, MAC clone |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2 |
Authentication Method | RADIUS |
Compliant Standards | IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac Wave 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x USB 2.0 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | RoHS |
Power | |
Power Consumption Operational | 19.2 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
