DrayTek Vigor P1092 PoE Web Smart Gigabit Switch
£158.66
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • LAN management
  • Speed up the network by link aggregation
Product codes
The VigorSwitch P1092 is ideal for SOHO and small business with the high-performance capability. To cater for high bandwidth traffic, it is equipped with Gigabit Ethernet ports for the LAN side, and SFP ports for the backbone side. VigorSwitch P1092 is equipped with extensive facilities for maximizing your LAN performance, VLAN capability to allow flexible network design, and QoS capability for flexible bandwidth control.
Draytek VigorSwitch P1092 - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
110 W
Performance
Switching capacity: 20 Gbps , Forwarding rate: 14.88 Mpps
VLANs supported: 8 , Link aggregation groups: 2 , QoS queues: 4 , Links per group: 2
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Remote Management Protocol
HTTP
Flow control, DHCP support, auto-negotiation, port mirroring, firmware upgradable, Weighted Fair Queuing (WFQ), Quality of Service (QoS), reset button, bandwidth control, IPv4 support, Link Aggregation Control Protocol (LACP), Class of Service (CoS), tagged VLAN, VoIP support, Storm Control, ingress rate limiting, Energy-Efficient Ethernet (EEE), port-based VLAN, egress rate limiting, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
26.5 cm x 18.4 cm x 4.4 cm
1.68 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
DrayTek Vigor P1092 Po...
£158.66
