Marketing description is not available.
Product Description | Draytek VigorAP 1060C - radio access point - Wi-Fi 6 - cloud-managed | Device Type | Radio access point | Form Factor | External | Localisation | United Kingdom, Ireland | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 1.2 Gbps , Maximum data rate (5 GHz): 2.4 Gbps | Capacity | SSIDs per radio: 8 , SSIDs total: 16 , Maximum number of clients: 256 , MAC address entries: 256 | Included Accessories | Ceiling mounting kit | Power Over Ethernet (PoE) Supported | PoE | Power | AC 100-240 V | Dimensions (WxDxH) | 20.5 cm x 20.5 cm x 3.32 cm | Weight | 809 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 20.5 cm |
Depth | 20.5 cm |
Height | 3.32 cm |
Weight | 809 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 3.6 Gbps |
Spread Spectrum Method | OFDMA |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069 |
Cloud-Managed | Yes |
Wi-Fi Rating | AX3600 |
Features | VLAN support, IGMP snooping, repeating mode, Syslog support, MAC address filtering, DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, hidden SSID, reset button, DHCP relay, DHCP client, ceiling mountable, Captive Portal, security lock slot (cable lock sold separately), wireless extender mode, Transmit Power Control (TPC), Pre-Authentication, band steering, PMK Caching, Airtime Fairness, 4x4 MU-MIMO technology, client isolation, Wireless Mesh support, MAC clone, AP-Assisted Roaming, 4x4 MIMO technology, Transmit Beamforming, Client Limit per SSID, BSS Coloring |
Encryption Algorithm | PEAP, WPA2-Enterprise, WEP, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, EAP-TLS |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11r, IEEE 802.11ac Wave 2, IEEE 802.11ax, Wi-Fi CERTIFIED 6 |
Aerial | |
Antenna | Internal |
Antenna Qty | 9 |
Expansion / Connectivity | |
Interfaces | 1 x 2.5 GBase-T (PoE) - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100-240 V |
Power Consumption Operational | 21 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
