DrayTek VigorAP 903 is a wireless access point with a 5-port switch for expanding the network wirelessly. LAN clients can join the network from one of the 5 Gigabit ports or the wireless connection. It is designed to provide a smooth wireless connection by supporting 802.11ac wave2 standard and providing advanced features, such as AirTime Fairness, Band Steering, and AP-Assisted Roaming.
Product Description | Draytek VigorAP 903 - radio access point | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2 | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 10.7 cm x 4.5 cm x 30.5 cm | Weight | 370 g | Manufacturer Warranty | 2-year warranty |
General | |
Built-in Devices | 5 port switch |
Width | 10.7 cm |
Depth | 4.5 cm |
Height | 30.5 cm |
Weight | 370 g |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 867 Mbps |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069 |
Features | Power over Ethernet (PoE), repeating mode, Syslog support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Mesh networking, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, hidden SSID, reset button, 2T2R MIMO technology, DHCP client, tagged VLAN, band steering, Airtime Fairness, AP-Assisted Roaming |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac Wave 2 |
Aerial | |
Antenna | External detachable |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 1 x USB 2.0 - Type A |
Power | |
Power Device | External power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
