Marketing description is not available.
Product Description | Draytek VigorAP 918R - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | Wall mountable - outdoor | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 866 Mbps | Dimensions (WxDxH) | 16.1 cm x 7.2 cm x 24.4 cm | Weight | 1 kg | Manufacturer Warranty | 2-year warranty |
General | |
Ruggedized Design | Outdoor |
Width | 16.1 cm |
Depth | 7.2 cm |
Height | 24.4 cm |
Weight | 1 kg |
Networking | |
Form Factor | Wall mountable |
Connectivity Technology | Wireless |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069 |
Wi-Fi Rating | AC1300 |
Features | Load balancing, repeating mode, Syslog support, MAC address filtering, DFS support, Wireless Distribution System (WDS) support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, RADIUS support, DHCP server, hidden SSID, temperature / humidity sensor, wireless bridge mode, reset button, 2T2R MIMO technology, pole mountable, DHCP relay, Transmit Power Control (TPC), band steering, Fast Roaming, RSSI Threshold, Airtime Fairness, client isolation, dustproof, waterproof, MAC clone, Wireless Auto On/Off, Multi-SSID over Mesh, Client Limit per SSID, Trusted DHCP Server IP for WLAN, Device Object/Group Control |
Encryption Algorithm | TLS, PEAP, WPA, WPA2, WPA-PSK, WPA2-PSK, WEP |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v |
Aerial | |
Antenna | External detachable |
Antenna Qty | 2 |
Directivity | Omni-directional |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 , 2 x aerial |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | IP67 |
Power | |
Power Consumption Operational | 18 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
