Marketing description is not available.
Product Description | Draytek VigorAP 960C - radio access point - Wi-Fi 6 | Device Type | Radio access point | Form Factor | Wall / ceiling mountable | Localisation | United Kingdom, Ireland | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps | Capacity | Wireless clients: 256 , SSIDs total: 8 | Included Accessories | Cover, mounting kit | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 17.8 cm x 17.8 cm x 3.5 cm | Weight | 380 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 17.8 cm |
Depth | 17.8 cm |
Height | 3.5 cm |
Weight | 380 g |
Networking | |
Connectivity Technology | Wireless |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069 |
Wi-Fi Rating | AX1800 |
Features | VLAN support, DFS support, firmware upgradable, Mesh networking, Wi-Fi Multimedia (WMM) support, DHCP server, DHCP relay, system log, band steering, VLAN management, Fast Roaming, PMK Caching, Airtime Fairness, client isolation, interference detection function, flow monitoring, MAC clone, schedule reboot, Multi-User MIMO & Beamforming technology, Orthogonal Frequency Division Multiple Access (OFDMA), self-healing network, Wireless Auto On/Off, Device Object/Group Control, Wi-Fi 6 technology, BSS Coloring, TCP support, PiFA Dual-Band Antennas |
Encryption Algorithm | PEAP, WPA, WPA2-Enterprise, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, EAP-TLS |
Authentication Method | RADIUS, Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x, IEEE 802.11r |
Aerial | |
Antenna | Internal |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | Power injector |
Power Consumption Operational | 11 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
