We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
VigorSwitch G1280 is designed for SOHO and small business network that runs various network applications. The Gigabit Ethernet ports are perfect for a network with wireless AP, IP phones, and IP surveillance.
Product Description | Draytek VigorSwitch G1280 - switch - 24 ports - smart - rack-mountable | Device Type | Switch - 24 ports - smart | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 + 4 x combo Gigabit Ethernet/Gigabit SFP | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP | Remote Management Protocol | SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, SSH, CLI, TR-069 | Features | Flow control, auto-negotiation, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, event log, Access Control List (ACL) support, Quality of Service (QoS), reset button, IPv4 support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, port isolation, Class of Service (CoS), DiffServ Code Point (DSCP) support, cable test, LLDP-MED, Unknown Storm Control | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az | Power | AC 120/230 V | Dimensions (WxDxH) | 44.1 cm x 19.7 cm x 4.5 cm | Weight | 2.6 kg | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, rack-mountable, wall-mountable 1U |
Status Indicators | Port transmission speed, power, system, link/activity |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 4 x Gigabit LAN RJ-45 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 453.3 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 19.7 cm |
Height | 4.5 cm |
Weight | 2.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
