Marketing description is not available.
Product Description | Draytek VigorSwitch G2100 - switch - 8 ports - Managed - rack-mountable | Device Type | Switch - 8 ports - L2+ - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 + 2 x Gigabit SFP (uplink) | Performance | Forwarding performance (64-byte packet size): 14.88 Mpps , Switching capacity: 20 Gbps | Capacity | Virtual interfaces (VLANs): 256 , QoS queues: 8 , Total link aggregation groups: 4 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, static IP routing, IGMPv3, MLDv2, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2 | Features | Flow control, auto-negotiation, load balancing, VLAN support, IGMP snooping, Syslog support, traffic shaping, E-mail alert, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, IPv4 support, LLDP support, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), ONVIF support, DiffServ Code Point (DSCP) support, Protocol-based VLANs support, IP source guard, layer 2+ switching, Link Aggregation, scheduler, rate limit, Authentication, Authorization and Accounting (AAA), IGMP querier, VLAN Double Tagging (Q-in-Q), Voice VLAN, VLAN management, LLDP-MED, Private MIB, Guest VLAN, Denial of Service (DoS) protection, DSCP based CoS, MAC based VLAN, loopback detection, Unknown Storm Control, 4.1Mbit packet buffer, Address Conflict Detection, OpenVPN client, DSCP based QoS | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3az | Power | AC 120/230 V | Dimensions (WxDxH) | 27 cm x 18.1 cm x 4.4 cm | Weight | 1.78 kg | Localisation | United Kingdom | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Authentication Method | RADIUS, TACACS+, Secure Shell v.2 (SSH2), internal user database |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP , 1 x console RJ-45 management |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 18 Watt |
Miscellaneous | |
Cables Included | 1 x console cable |
Rack Mounting Kit | Included |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 27 cm |
Depth | 18.1 cm |
Height | 4.4 cm |
Weight | 1.78 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
