Draytek VigorSwitch P-2261 PoE Gigabit Ethernet Switch
Key features
  • 24+2 port PoE managed switch
  • 20 x 10/100/1000Base-T Gigabit Ethernet ports for the LAN side
  • Fiber connectivity for the backbone: 2 SFP ports and 4 Combo UTP/SFP ports
  • Advanced security for remote access, IP Source Guard, 802.1x access control, and so on
  • Access Control List (ACL) to prevent unauthorized access
  • VLAN features provide both security and performance
  • Dedicated Voice VLAN to prioritize voice traffic automatically
  • Advanced QoS for application traffic prioritization
  • UPnP for simple connectivity
  • Power saving by 802.3az Energy Efficient Ethernet
  • sFlow sampling protocol monitors network traffic without interrupting data flow
  • IPv6 and IPv4 conformity for the next generation network
Product codes
VigorSwitch P2261 is a L2+ managed PoE switch designed for small to medium sized businesses. It offers Power over Ethernet feature to ease the field deployment tasks. To cater for high bandwidth traffic, it is equipped with 20 Gigabit Ethernet ports for the LAN side, and 6 Dual SFP ports, 2 of which are for fiber and the other 4 can be used for either UTP (Ethernet cable) or SFP (fiber) connections, for the backbone side. It has security features to meet the needs of managing local and remote access to the network. Furthermore, it has VLAN capability to allow flexible network design, and QoS capability for flexible bandwidth control. It supports 802.3az energy saving standards, sFlow network monitoring, IPv6 and IPv4 and many other functions. With preset options for configuring network devices and plug and play features, this switch is truly an ideal solution for business grade network infrastructure.
Product Description Draytek VigorSwitch P2261 - switch - 24 ports - Managed
Device Type Switch - 24 ports - L2+ - Managed
Subtype Gigabit Ethernet
Ports 20 x 10/100/1000 + 4 x combo SFP + 2 x SFP
Power Over Ethernet (PoE) PoE
PoE Budget 185 W
Capacity Virtual interfaces (VLANs): 4096
MAC Address Table Size 8K entries
Jumbo Frame Support 9600 bytes
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Features Flow control, Layer 2 switching, auto-negotiation, trunking, VLAN support, IGMP snooping, port mirroring, DiffServ support, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, IPv4 support, LLDP support, DHCP relay, Generic VLAN Registration Protocol (GVRP)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44.2 cm x 30 cm x 4.4 cm
Weight 4.6 kg
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Draytek VigorSwitch P-...
