We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
DrayTek VigorSwitch P2500 is a Layer 2 Managed Gigabit PoE switch. It has 44x Gigabit Ethernet PoE/PoE+ ports with a power budget of 405 watts. Perfect for a business network with many PoE devices. It also has 4x GbE/SFP combo ports, 2x SFP ports, 1x console port, and enterprise-level features to help businesses to improve network security and stability.
Product Description | Draytek VigorSwitch P2500 - switch - 50 ports - Managed - rack-mountable | Device Type | Switch - 50 ports - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP + 2 x SFP | Power Over Ethernet (PoE) | PoE+ | Performance | Switching capacity: 56 Gbps , Forwarding rate: 41.7 Mpps , Packet buffer size: 12 Mbit | Capacity | Multicast groups: 256 , Total link aggregation groups: 16 , Links per group: 8 , ACL entries: 512 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 12KB | Routing Protocol | IGMPv2, IGMPv3, MLDv2, MLD, MSTP, STP | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, RSTP | Features | Flow control, DHCP support, auto-negotiation, trunking, load balancing, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support, MLD snooping, reset button, IPv4 support, fanless, LACP support, LLDP support, Link Aggregation Control Protocol (LACP), Traffic Control, port based access control, Multicast VLAN Registration (MVR), Multicast filtering function, Class of Service (CoS), Strict Priority (SP), DiffServ Code Point (DSCP) support, Protocol-based VLANs support, IP source guard, ARP inspection, Voice VLAN, VLAN management, LLDP-MED, Guest VLAN, protected ports, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), VLAN Tagging, port-based VLAN | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3q, IEEE 802.1az | Dimensions (WxDxH) | 44.1 cm x 27 cm x 4.5 cm | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Authentication Method | Secure Shell (SSH), RADIUS, TACACS+ |
Status Indicators | Port transmission speed, power, system, link/activity |
Expansion / Connectivity | |
Interfaces | 44 x 1000Base-T RJ-45 , 4 x Gigabit LAN RJ-45/SFP , 1 x console RJ-45 management , 2 x Gigabit LAN SFP |
Power | |
Power Device | Internal power supply |
Miscellaneous | |
Rack Mounting Kit | Included |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 27 cm |
Height | 4.5 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
